2 15" wiring - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 10-14-2006, 08:47 PM
hevychevy
i forgot how 2 wire these- i have 2 15" woofers but 1 is a 4ohm dvc and the other is a 2ohm dvc , how can i wire these up 2 a amp thats bridged at 4ohms??
post #2 of 12 (permalink) Old 10-14-2006, 09:21 PM
Impholla
hmmm.. let me think on that,
post #3 of 12 (permalink) Old 10-14-2006, 10:13 PM
BuickMaster
the dual 4 can be wired to 2ohms and 8ohms. and the dual 2 ohm can be wired to 1ohm and 4ohms. so either way you're not gonna have a nice impedance.
post #4 of 12 (permalink) Old 10-15-2006, 10:22 AM
hevychevy
any suggestions on how i could wire them up to sound good?
post #5 of 12 (permalink) Old 10-15-2006, 10:59 AM
USAFCaprice
your not gonna be able to match your impedance so either way one is gonna hit harder(one w/ least resistance.) just run the 4ohm sub at 2 ohms bridged on your amp. or if it's one ohm stable run the dual 2 at one ohm.
[ 10-15-2006, 12:07 PM: Message edited by: USAFCaprice ]
post #6 of 12 (permalink) Old 10-15-2006, 01:11 PM
hevychevy
can anyone draw up a diagram showing how i should wire these up to the amp
post #7 of 12 (permalink) Old 10-15-2006, 08:30 PM
USAFCaprice
go here-http://jbone.8m.com/heavychevy.gif
post #8 of 12 (permalink) Old 10-16-2006, 08:35 AM
PIMPALA-SS
you can not wire that CORRECTLY and make it sound good.
the only way to do it, is to parallel the DVC4 sub, making it 2 ohm, and leave one VC open on the DVC2 sub, forcing them both to be a 2 ohm speaker, then wiring them to the amp. (or the opposite with the DVC2 being series, and the DVC4 leaving one open)
however, you "may" cause damage to the speaker with the open VC, so i can not tell you that its a good idea.
post #9 of 12 (permalink) Old 10-20-2006, 01:24 PM
gvillepoet
man i wouldnt even go through the headache or time....just dont take the chance
post #10 of 12 (permalink) Old 10-20-2006, 05:33 PM
USAFCaprice
that's what i was trying to say but he's got the "new sub itch" hopefully one or both wont end up as toast
