Speaker locations - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 08-17-2003, 09:38 PM
miket
Does anyone have any ideas or seen speakers mounted in areas in the 94-96 B-Body's other than stock locations? IE...Kickpods, rear doors????
post #2 of 5 (permalink) Old 08-18-2003, 12:25 AM
JaiB
Ive seen kick panels, but i hear there hard to do beacuse of the e brake and computer
For the back, ive seen in the rear doors, prolly very easy since theres room there already. Ive seen in the C pillar, but it covered the window, and ive seen it moved around in the rear deck in order to make room for subs
post #3 of 5 (permalink) Old 08-18-2003, 07:57 PM
xtremeimpalaSS
check out my car i put speakers in the rear doors
post #4 of 5 (permalink) Old 08-28-2003, 08:23 AM
WILDSS
I've mounted tweeters on the front door skins, and in the rear on the pillars. Next thing to think about is where to mount crossovers if any. I mounted the rears to the bottom of the rear deck and mounted the fronts in the door opening w/o a problem. If you wanna check out some install pics check out my sounddomain url
Jim
post #5 of 5 (permalink) Old 08-28-2003, 02:27 PM
bbodyguy
I mounted some expensive tweeters behind the air vents in each corner in addition to the components in the door. I played with phase for a while, and decided it sounded better inverted. It really was impressive how much it brought the soundstage "up" from down lower.
Peter
