i have a idea - Chevy Impala SS Forum
post #1 of 10 (permalink) Old 03-07-2007, 05:29 PM
Lightbulb
okok, i am no audio pro so i turned here to get your thoughs on my idea...
ok
i have 2 JL Audio W6 12's, gonna be push by a 1 ohm load at 1000ish watts, i want to put them in a JL spec box,then i want to mount them facing up to the back window, cut holes in the back dash, cover with a grill and acualy mount/hand them from the back dash so the subs will hit in the caben....
kinda get the idea?
or i just cut holes and mount them to the back dash with no box but then i am not sure what will sound better.
post #2 of 10 (permalink) Old 03-07-2007, 07:29 PM
9C1BALLN
The W6 JLs will work in a box built to specs. You dont want to use them as free air (just throwing them in the rear deck with no box).
I believe there are a couple who have built their systems the way you describe as far as building the box pointing up through the rear deck. So i will let them chime in. You will def get a better sound by doing it this way. Good luck I will look for some pics to give ya some ideas on what others have done.
post #3 of 10 (permalink) Old 03-07-2007, 09:48 PM
JAYO96SS
Contact E-Dogg.. He has what you are looking for with W6's.. His trunk is so sexy!
post #4 of 10 (permalink) Old 03-07-2007, 10:39 PM
PIMPALA-SS
W6 will not work in an infinite baffle.
you will need to build a box, and mount it under the rear deck, and then cut it all out.
its been done a hundred times, but it sounds like you need someone who has done it before to either help you, or take it to a shop and have them do it for you.
post #5 of 10 (permalink) Old 03-08-2007, 12:03 AM
thanks more feed back is THANKS! haha
ya so pictures would be great... should i mout them right there or just cut a hole and let the bass flow in the caben? will there like "tube sound" if i cut a hole?
post #6 of 10 (permalink) Old 03-08-2007, 12:08 AM
there is no E-Dogg
post #7 of 10 (permalink) Old 03-08-2007, 12:39 AM
Daniel Reynoso
Thumbs up
Originally posted by thebigbadWOLF:
there is no E-Dogg
OH YES THERE IS!
I have an Idea, look for member STRTWYZ
post #8 of 10 (permalink) Old 03-08-2007, 01:07 PM
elvistass
Say I wanna do the same thing, I was going to start on mines next week during spring break, only difference is im running with some pioneer subs. Ill also take any advice in the box building and porting the rear deck.
post #9 of 10 (permalink) Old 03-08-2007, 01:32 PM
i guess the next question is do i build a box that hangs from the back deck or build the box upto the back deck
post #10 of 10 (permalink) Old 03-08-2007, 02:14 PM
JAYO96SS
Originally posted by RhinoSS:
</font><blockquote>quote:</font><hr />Originally posted by thebigbadWOLF:
there is no E-Dogg
OH YES THERE IS!
</font>[/QUOTE]
Originally posted by STRTWYZ:
Yes Sirrrrrrr! E-Dogg goes by STRTWYZ now.
