Wagon rear cargo speakers - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 11-26-2006, 08:09 AM
krzdimond
Hey guys, I've got an "issue" with my rears; seems that there is "little" sound back there. No volume and no bass. I even replaced the speakers with a set of Pioneers by hooking them up to the stock harness (not installed) with the same results Is it my head unit, or is this common with all of the wagons? Also, what size are these speakers?
I want to keep the (a) stock head unit because the crime rate here is WAY high.
As always, any help would be apreciated
post #2 of 4 (permalink) Old 11-26-2006, 11:34 AM
UndercoverPunk
I can't tell you how to fix it, but I can verify the same problem. I haven't really addressed the issue as I won't be using rear fill.
Hopefully someone else has fixed the issue.
post #3 of 4 (permalink) Old 11-29-2006, 01:48 AM
12-pack
same in my impala ss i tried to install aftermarket 6x9's in the rear deck no power so i reinstalled stockers unti, deck unit is replaced in ur case id suggest a cheaper 4 ch amp which with the correct setup can be used with factory head unit
post #4 of 4 (permalink) Old 11-29-2006, 06:29 PM
krzdimond
so all the factory headunits that are bad?
