Why can't I hear my bass? - Chevy Impala SS Forum
post #1 of 14 (permalink) Old 01-17-2007, 01:50 AM
sik96ss
Really having a problem getting the bass to travel in the car from the trunk. I have tried several different set-ups,both using lots of power, but I all I get is trunk rattle and little bass in comparison to the equipment I'm using.I've heard to port the rear deck.The power Isnt the issue Its the box design.can somebody help me out.
post #2 of 14 (permalink) Old 01-17-2007, 03:24 AM
easter9053
Maybe you have to cut hole in rear deck and the have a box built so that it ports all the sound to the cabin. I did that once on a design built by a stereo shop in town and the thing didn't have any bass in the trunk just in the cabin.
post #3 of 14 (permalink) Old 01-17-2007, 09:59 AM
UndercoverPunk
got any pics of the setup?
post #4 of 14 (permalink) Old 01-17-2007, 10:16 AM
shaggunwagun
I concur with Easter. Have done many setups in Impalas and Caprices at my last job and the only way to get a good bit of sound into the cabin is to do a ported rear deck. I have done it multiple ways with large square small slot and variations in between. We did a bandpass with front sealed facing outward and the ported deck running thru the rear deck. I have also done it to where you just shave the insulation off of the rear deck carpet to where the port is firing at the uninsulated area so as to leave a stock looking interior. The only downfall is that it flaps a little while playing. I wish I had some pics but unfortunately I do not. But as far as porting thru the rear deck, get someone to run your specs thru like bassbox etc... and tune it correctly to take into consideration the port externally from the box. Also a helpful hint is to build the port with the extension from the box and the actual visible piece for the rear deck in two pieces. A lot easier to install.
post #5 of 14 (permalink) Old 01-17-2007, 11:01 AM
the96pala
Yo man, I had a ported box in the trunk, just thrown in there and I could clearly hear the bass was muffled so we cut a hole in the rear deck, like a 4"x8" hole and it made a hell of a difference....
post #6 of 14 (permalink) Old 01-17-2007, 02:22 PM
glennSS
Yeah, I have my subs in the quarter panels and a 10"x15" hole cut in my deck and the bass travels through really well. It'll shake the fillings out of your teeth.
post #7 of 14 (permalink) Old 01-17-2007, 05:11 PM
sik96ss
So,I do need to cut a hole in the rear deck? I planned on putting a sealed box.I also thought of going with a free air type setup,mounting the sub or subs like the 6x9's are.Just trying to get the most effective design.
post #8 of 14 (permalink) Old 01-19-2007, 03:49 PM
shaggunwagun
Hit up cam and ask him for some pics of his back window.
post #9 of 14 (permalink) Old 01-22-2007, 02:48 PM
pappa sulley
So how would somebody go about porting the rear deck. It sounds like this would help my situtaion. Any idea on time or difficulty?
Thanks
Mike
post #10 of 14 (permalink) Old 01-22-2007, 03:01 PM
the96pala
I paid to have mine done. I've got pics on the link in my sig.
I would guess if you had the time, about a week or so to do it right
