Batt drainage.... - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 03-10-2002, 06:21 AM
GhoSStRyda
Unhappy
im crusing the freeway @ 80mph with my system bumping some heavy bass rap~ all of a sudden with out warning my car dies~~ i was like WTF~??? i turned off the stereo and hazarded my way to the side of the freeway and started the car back up... it hesitated and i gave it some gas and revved for a minute... i think my stereo has just drained my 3 month old DieHard battery~!!!
i dont have a volt meter so im not sure if this is the cause but im almost sure it is... i guess i'll be making a trip down to sears to see if my battery is toast.... [img]1.gif[/img]
post #2 of 5 (permalink) Old 03-10-2002, 07:34 AM
Steve Cornell
If your system had drained your battery it would not have started once you pulled to the side of the road......
post #3 of 5 (permalink) Old 03-10-2002, 03:19 PM
GhoSStRyda
<BLOCKQUOTE>quote:</font><HR>Originally posted by Steve Cornell:
If your system had drained your battery it would not have started once you pulled to the side of the road......<HR></BLOCKQUOTE>
thanks steve! ok... hmm... any ideas what might have happened?? im totally clueless now... anyone else?
post #4 of 5 (permalink) Old 03-10-2002, 05:23 PM
cats95ss
I agree with Steve. Once your car is running your car and stereo should run off of the altinator, unless your pushing some serious wattage where your current demand is more than your altinator can put out. Your battery is actually another load on the altinator when the car is running.
My first guess would be that your fuel pump might be going bad. I had an old honda that died on me like your car. I was also able to get the car started again. It did this to me several times over the course of a few weeks. Each time took a little longer sitting on the side of the road before the car would start. What I found out was that the fuel pump was overheating and locking up. After it cooled off the car would start and run fine untill it decided to hang up again.
I hope this helps.
Cory
post #5 of 5 (permalink) Old 03-11-2002, 07:43 AM
gbelli
Have good 'ole sears check out the battery Its free!
