How many subs with Hydros? - Chevy Impala SS Forum
post #1 of 12 (permalink) Old 06-15-2002, 11:38 AM
DaytonaFBody
I thought I'd ask someone in here because I'm sure someone knows. I'm going to be putting 3 pumps and 5 batteries (60V system) in my trunk for my new hydraulics on my 94 9C1. But I was looking at the space beneath the rear deck, and I would like to go bandpass with 12" subs. How many could I fit in there, realistically? I was thinking 3 or maybe 4. Trunk space obviously isn't a concern, although I'll probably build a clear plexiglass cover over the pumps and batteries so I can still put some stuff in it.
How much power do I need to really make the car loud as heck?
My 93 Z28 has 2 12" RF subs in it with 300W (MTX 752 2 ohms mono) and it hits hard, but I asked a friend of mine about putting that in the Caprice and he made a point that the car is so much bigger I probably won't hear it.
post #2 of 12 (permalink) Old 06-15-2002, 03:46 PM
4doorSS
its not the amount of batteries, people run more batteries basicly to power all there amps,not to push more into the amps, i just run one battery, i got a 600 and a 100 amp in my car, and i have no problems.
post #3 of 12 (permalink) Old 06-15-2002, 08:27 PM
ShowSS12
4doorSS: I think the batteries are for the hydros
post #4 of 12 (permalink) Old 06-15-2002, 10:33 PM
E-Dogg
Yo DaytonaFBody!
First of all, why three pumps? Are you planning to go two gates to the front and the third for your booty? If so, why only 5 batteries and why two gates to the front? Are you planning to swing it? What kind of dumps? OG squares or delcos? Did bagging it ever cross your mind instead of "cutting" it?
I think it'll be easier to build your beats around the juice but it's all about you. I personally think three gates are too much unless your trying to swing and if your trying to swing, 5 batteries aren't going to be able to squash grapes!
Just my $0.02.
Juice is like going fast, the higher and faster you wanna go, the more money it takes.
post #5 of 12 (permalink) Old 06-16-2002, 07:42 AM
camel
looking and measuring the space under the rear deck, i think you will have troubles putting 2 12's in sealed boxes let alone bandpass. if you are going you use some of your trunk you may be able to go ported. ported is the way to go if you ask me. its going to be hard to get all that stuff in there, if it will even fit.
post #6 of 12 (permalink) Old 06-16-2002, 12:51 PM
4doorSS
Whoops, i knew i could read way to fast! hehe, so yea i have 3 subs in my trunk (10"s) with a 600w amp to them, Seald box, sounds really loud, its more of the box design to get it so far back so you can stil have room for the pumps an amps....
post #7 of 12 (permalink) Old 06-17-2002, 10:45 AM
jelzey
First. 5 batteries to aside is what I think he meant but if you are talking just one bank then there will be issues. I assume if you meant 2 banks of 5 batteries you are trying to 3-wheel or hop higher. Only reason you need 3 pumps or want them. You will be able to get 2 12" betweend the cylinders under the rear deck and allow room to service the cylinders. What size cylinders are you goin with? That makes a difference to. I just juiced my front end and will finish the back this week (fingers crossed). I plan on running 3 12's that go across the rear deck. I will be happy to answer any more questions you have. If you are only 1 bank of batteries, you will be charging them every month. It goes fast the more you hit the switches. I would look into a street charger if it is daily driven (www.streetcharger.com). Later
post #8 of 12 (permalink) Old 06-17-2002, 06:30 PM
E-Dogg
Sorry, 3 wheeling can be achieved with a standard 2 pump set up. Your run of the mill front, back, side to side, pancake and individual corners for three wheel motion.
post #9 of 12 (permalink) Old 06-17-2002, 08:12 PM
jelzey
OK!!!!!!!!!!!!!!! First you need three punps to do a standing 3-wheel. Two pumps only allows a moving 3-wheel and is not good for the ride. Now if cash is not a problem then you can accomplish a 3-wheel with 2 pumps by modding the suspension. Lets see 1-2 grand for modding the suspension or 400 for another pump. You can only get a standing 3 -wheel with 2 pumps for short wheel based rides like imports. But we have huge cars on this forum
BTW DaytonaFBody. I got your email today but I was out the door going out of town for work. I will get back to you Thursdays. You do not want to go more then 12's in the back unless you want to cut the rear dash and risk hitting the rear window. Sounds like that guy had a sic S-10.
post #10 of 12 (permalink) Old 06-17-2002, 09:23 PM
E-Dogg
Yo TWiG,
Bro, listen to me, tap in to your dumps in the rears to add a switch for each corner and your set. End of story. Don't get it twisted, I've seen this with my own eyes and is s.o.p. here on the streets. Of course it's a big car and the proper strapping of the frame, reinforcing the quarters and rear end is a must!
No need to have the guy spend money for a pump he doesn't need.
