General Impala Audio Upgrade ?s - Chevy Impala SS Forum
post #1 of 3 (permalink) Old 04-03-2002, 07:41 AM
lt1srule
First off, the factory deck and speakers seems ok to almost enjoyable for some music, but some songs sound really flat with it. So after 3 yrs of ownership, I have bought a Sony CDX-M750 to replace the factory unit. I am sticking with Sony because I have an older style 10-disc CD changer that can share magazines with the 10-disc home unit.
My first question is whether the factory speakers will sound better with the upgraded head unit or will they really limit the gain I hear? It is a matter of cost right now, so I will evetually upgrade the speakers, as I don't doubt that gains can be made here as well. The head unit puts out 19 watts RMS and 50 peak for reference. Is this too much power for the factory speakers?
Next question is relating to your experience with the dash adapters and how a single DIN units looks in the Impala after installation? Is there a particular adapter that works better than others? Is there a choice in mounting it toward the top or bottom rather than the standard in the middle adapter I usually see?
Lastly, I will mount the changer somewhere in the trunk, probably under the rear deck facing toward the trunk opening. I have 2 extra changers, so I was thinking of putting one on either side of the spare tire for those long road trips. What's the best way to route the RCA cables and Uni-link cord in the Impala on the way to the trunk? Will I have to remove the rear seats? Any experience you all can relate will be greatly appreciated.
Thanks,
David
post #2 of 3 (permalink) Old 04-03-2002, 08:00 PM
MrSag
Change all the factory "paper cone" speakers to better ones. Might also want to get an external amp if you like listenning to ur music at very high volume.
post #3 of 3 (permalink) Old 04-03-2002, 11:24 PM
andrew9C1
Thumbs up
I dropped an Eclipse CD deck into my 9C1 as the only audio upgrade, and the sound is much better than the sound in my SS which is all stock.
That said, I'd still recommend buying some other speakers, even if they'd only be driven by the head unit. If you can afford an amp, icing on the cake.
