help - Chevy Impala SS Forum
post #1 of 2 (permalink) Old 12-14-2006, 07:39 PM
96purplehaze
i was tuning my amp and one of my subs got disconnected. it was dark and couldnt match the wire to the sub connector then now my other sub does work. both dont work now. the amp still works and checked the fuses
post #2 of 2 (permalink) Old 12-19-2006, 01:50 PM
420 CAPRICE SS
check if the speaker wires are grounded or touching eachother, just one strand can cause problems. if you push in on the subs and they grind or catch, get new subs. if the speaker wires were shorted, you could have blown the amp's signal circuit. try replacing the wire with fresh 12 gauge. if they're DVC subs, replace that wire too. and for god's sake man keep a flashlight in your car.
