speaker ohm ? - Chevy Impala SS Forum
post #1 of 8 (permalink) Old 06-28-2003, 04:52 AM
SSGUSS
If I have an amp that has 100 watts to a 4ohm speaker. What would happen If I hook two 4ohm speakers to the one side (channel)? Is that an 8 ohm load to that channel and only 50 watts to each speaker How does this work and does it cause any possible problems. Thanks for any and all info.
post #2 of 8 (permalink) Old 06-28-2003, 06:58 AM
chevmdnss
Let's get a little more info. It all depends on the amp.
Is it 2 channel, 4 channel, 1 channel??
Is that 100 watts at 4 ohm stereo or mono?
If you connect both postives to the positive side and both negatives to the neg side, then you will be a 2 ohms, and that could be bad.
post #3 of 8 (permalink) Old 06-28-2003, 12:49 PM
BanginBubbleBody
http://www.outerlimitsaudio.com/dire...CategoryID=266 that will show you how to wire your subs, it depends on what kind of amp tho on how you want to hook it up to the subs.
post #4 of 8 (permalink) Old 06-28-2003, 08:47 PM
SSGUSS
I have a soundstream Lilttle Wounder amp 200 and (2) Soundstream D100 amps.
post #5 of 8 (permalink) Old 06-28-2003, 09:36 PM
bbodyguy
Are the amps two ohm stable? If yes, than you can wire the subs parallel, if not, then you cant.
Peter
post #6 of 8 (permalink) Old 06-30-2003, 08:40 PM
SSGUSS
This is from there web site.I have the LIL wounder for my sub`s. All amplifiers: THD: < 0.1% (20Hz to 20kHz) 4 ohm, 12.6v. Signal-To-Noise: > 100dB. *This is not a mistake! **Fixed - F; Variable - V; Parametric - P Due to continuing improvements product specifications are subject to change. (The Lilí Wonder) measures 7 x 113/8 x 21/4 . The Lilí Wonder 4 measures 11 x 113/8 x 21/4
post #7 of 8 (permalink) Old 06-30-2003, 08:43 PM
SSGUSS
Rated Power (2 ohms, 14.4V) Do I need a Farid Thing? so not to kill my battery or cook the alt. ?
post #8 of 8 (permalink) Old 07-01-2003, 08:15 AM
Wagon Boy
so its only puttin out about 100 watts or like 200 max?
No u don't need a capacitor.
I just purchased a soundstream tarantula amp thats [email protected] and i'm going to run a 2nd battery and a cap.
