ported my rear deck..update w/ pics - Chevy Impala SS Forum
post #1 of 20 (permalink) Old 03-20-2007, 08:11 PM
9c1 lover
now i have a ported box should i seal it? ports facing away from cab right? do 6x9's need to be sealed from cab now?
[ 04-22-2007, 05:29 PM: Message edited by: 9c1 lover ]
post #2 of 20 (permalink) Old 03-20-2007, 08:40 PM
Daniel Reynoso
Can you post pics?
[ 03-20-2007, 09:53 PM: Message edited by: RhinoSS ]
post #3 of 20 (permalink) Old 03-20-2007, 08:47 PM
Daniel Reynoso
How big did you make the port?
[ 03-20-2007, 09:52 PM: Message edited by: RhinoSS ]
post #4 of 20 (permalink) Old 03-21-2007, 02:04 AM
cashmoneyspeed
Here's what i did. I ported my rear deck by using Four 3 1/2" speaker ports and the wrapping black pantyhose over them(sounds silly, i know) but it gives the look of speaker grills. I've run a bandpass box, ported, and sealed with no noticable difference in regaurds to the bass cancelling out the mid and high range. I'm also running infinity kappy perfect 6 x 9's in the rear along with infinity 6 3/4" in the front doors that are all powered off a RF 4 channel 400W amp. It sounds sooooo clear. Also, i used sound insulation on all 4 doors and the trunk and as soon as i get the time, i'll be doing the floor, roof, pillars, etc...
I say just leave the ported box alone if that's what your speakers are tuned for.
post #5 of 20 (permalink) Old 03-21-2007, 01:56 PM
Fleetwood4Life
How do you like the Infinity Kappa's ?
I am geeting the 6 1/2 componets for the door and two more 6 1/5 3 way's for the rear deck in a fiberglass box under the Deck to reay get the mid bass. But I wanted to know how good is the mid base and do you like the fact that they are 2ohm's?
post #6 of 20 (permalink) Old 03-21-2007, 02:50 PM
the96pala
I had Infiniti Kappa Perfects, 6x9's and 6.5's. I blew the 6x9's so I switched to Alphasonik. The 6.5 speaker sounds great, still got it but the nickle sized tweeters were shot within an hour. So again, I switched to some 2" Alphasonik tweeters. If the tweeters on the components are what I think they are, throw them in the trash now and save yourself the hassle.
post #7 of 20 (permalink) Old 03-21-2007, 04:11 PM
cashmoneyspeed
[/qb][/QUOTE]How do you like the Infinity Kappa's ?
I am geeting the 6 1/2 componets for the door and two more 6 1/5 3 way's for the rear deck in a fiberglass box under the Deck to reay get the mid bass. But I wanted to know how good is the mid base and do you like the fact that they are 2ohm's? [/QB][/QUOTE]
I like them, they were a drastic improvement over the stock ones. I had them in for awhile without an amp, and then after wiring them to the 4 channel amp they sounded even better. Midbass is decent but not the best that's out there, still great for the money though.
post #8 of 20 (permalink) Old 03-21-2007, 05:33 PM
elvistass
Got any pictures of the port?
post #9 of 20 (permalink) Old 03-21-2007, 08:08 PM
9c1 lover
pics to come this weekend. port is 6x11, made it out of wood i think it looks good. im gonna get like 3 tan bandanas and wrap the wood so it matches my interior. i want to slowly do bandana print accents in the cab this summer .
post #10 of 20 (permalink) Old 03-22-2007, 12:45 PM
elvistass
Ill be lurking around for those pics.
