new free airs???? - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 06-24-2002, 11:19 PM
greenz
are there any car audio company's besides pioneer that put out free airs. kicker doesn't do them anymore and im looking to get warrenty/new model(2002) free air 10's or 12's. what would be the best setup for a 600watt amp(model in sign) it says it pushes 300x1 2ohms so would 2 12's would get 300 watts each? also how much will 3 10's get?
post #2 of 5 (permalink) Old 06-25-2002, 05:01 AM
Knightshade
JL Audio sells freeairs in both 10 and 12 inch sizes.
post #3 of 5 (permalink) Old 06-25-2002, 09:02 AM
camel
if you had 2 4ohm speakers and hooked them up they would be sharing 300 watts at 2 ohms. so each sub would get 150watts at 4ohms. when you bridge an amp the resistance halves and the wattage usually doubles so long as the amp can run that low of a load. i'd go with the jl's if it was my money, check on the net for them and you can most likely get a good deal. and i think the jl's are rated at around 125 watts or so, which would be a nice combo. most subs blow from underpowering not overpowering.
post #4 of 5 (permalink) Old 06-25-2002, 09:05 AM
catdaddy
you can use the kicker comp vr's in a free-air install.
post #5 of 5 (permalink) Old 06-25-2002, 03:08 PM
greenz
thanks camel thats exactly what i will do
