1996 Power problems - Chevy Impala SS Forum
post #1 of 5 (permalink) Old 07-17-2019, 11:50 AM Thread Starter
1996 Power problems
Hello everyone I’m Jason I’m new here. I’ve been contemplating purchasing a 96 impala for the last few months the one I want to buy is having a power problem. The car starts and runs and drives well unless you put your foot into it. If you give the car more than half throttle the motor sounds like it’s miss firing, like the fuel cut out. Again runs well at low rpms. Any suggestions for great shops in Portland or area
Jason Adams is offline
post #2 of 5 (permalink) Old 07-19-2019, 06:52 AM
96ssguy's Avatar
Welcome! I would say if it is in good condition and the price is right get it. They are getting hard to find. The issue could be anything, low fuel pressure, wires, plugs, vacuum line ect.... Keep us posted
96 Impala, six speed,spec 3 clutch, center force flywheel,
eaton posi w/4.10s
160 TS, TB bypass, Bonneville seats
2.5" exhaust, K&N intake, PCM forless tune.
96ssguy is offline
post #3 of 5 (permalink) Old 07-19-2019, 11:11 AM
angelo's Avatar
Hi Man !
since it's a 96 you can put a scanner on it easy like a ELM327 and torque app on Android phone and watch what is EFFed up like O2, or MAF or fuel trims...
But my guess is fuel pressure check it first thing, cuz easy to rule out.
-ALF out...
ECIRS #427 ISSCA #01978
CLICK ME !!!
angelo is offline
post #4 of 5 (permalink) Old 07-24-2019, 07:02 AM
Vendor
carid's Avatar
Welcome to the forum, good luck and enjoy the search. Post a picture when you get your new Impala home.
Chevy Impala http://www.carid.com/chevy-impala-accessories/
Call Toll Free: 800.505.3274 | Facebook | Twitter | Google+ | YouTube
carid is offline
post #5 of 5 (permalink) Old 07-25-2019, 02:19 PM
If fuel pressure is too low, check fuel pressure regulator [underhood, behind engine].
IFF your fuel pressure is good:
Check coil
Check coil driver module
Check Opti-snorkel aka Opti Vent Vacuum Harness
Check for vacuum leaks between MAF sensor & O2 sensors
They are NOT Lying to You
You are Not Lying to Yourself
Alone (aka The Last Psychiatrist)
Marky Dissod is offline
