Stripped Camshaft???? - Chevy Impala SS Forum
post #1 of 4 (permalink) Old 03-08-2019, 08:49 PM Thread Starter
Hello all
took my car to mechanic to install opti spark
he didn't know what he was doing
took me a year to educate myself on opti spark and timing
replaced it myself
Car drove wonderful over a year
Found that it was time to replace my timing cover gasket
REPLACED!!!!
now i can't get the crank hub on the camshaft because I fear the camshaft is stripped
Couldn't get a threaded 7-16-20 rod to screw in tight
Always has too much "wiggle room" and can not tighten with installer tool (washers and bolts)
Any help?
getochild81 is offline
post #2 of 4 (permalink) Old 03-08-2019, 10:40 PM
The camshaft is hardened and tempered steel. It is nearly impossible to strip the threads. You may have the wrong size bolt.
post #3 of 4 (permalink) Old 03-09-2019, 04:46 AM
I am sure you mean the crankshaft, not the camshaft, because there's no hub on the cam.
The bolt hole is probably stripped and its not the end of the world. HeliCoil makes an insert kit and it works fine. It's a bitch to do with the engine in the car, but it can be done if you're careful. Ideally, remove the radiator and condenser so that you can see what you are doing and make sure the drill is straight.
atlantadan is offline
post #4 of 4 (permalink) Old 03-09-2019, 11:22 AM
OP
Think you are referring to crank shaft. You can "try" a thread tap tool same size/thread pitch as hub bolt to see if you can chase the threads clean.
What may have happened is someone tried to put the hub on crank by pulling it on with the bolt. There are only a few threads the bolt would catch on with the hun just starting on the crank so not much thread grab and the first few threads in the crank will strip but the rest should be fine if this was the case
you never want to use a damper hub bolt to "pull" the hub on. Make a home made install tool using all thread rod, washers, thrust bearing and a nut
If the threads are really FU and a tap won't fix them....you have to install a heli coil as Atlanta notes
Similar Threads
Picking the right camshaft... JRS9C1 Engine Performance 16 09-07-2008 11:46 PM
Camshaft For 96 CAprice With L99 Metallic Monster Engine Performance 2 05-19-2008 06:27 PM
Specs On 4.3l Camshaft? BigBodyBuilder Engine Performance 4 02-18-2008 08:14 PM
where to get camshaft dowel pin bigdan Engine Performance 3 11-16-2007 09:15 AM
Stripped Oil Plug, No stripped oil pan hole jthomasma Engine Problems/Maintenance 13 03-15-2007 01:46 PM
