Stock fuel pump does it max out @ 50psi? - Chevy Impala SS Forum
post #1 of 7 (permalink) Old 04-02-2019, 10:45 AM Thread Starter
babywag's Avatar
I searched but didn't find the info.
Does the stock pump in these max out @ ~50psi?
The reason I ask is using one on an engine run stand and seems to not go any higher even without vacuum applied to the regulator.
babywag is offline
post #2 of 7 (permalink) Old 04-02-2019, 12:14 PM
DeuceSS's Avatar
Fuel System
check the paragraph under the chart. not sure if accurate, just what i stumbled upon when i was researching upgrading my pump
hope that helps
DeuceSS is online now
post #3 of 7 (permalink) Old 04-02-2019, 02:41 PM
Stock regulator will max out 41-47psi. An adjustable regulator would let it go up until nothing goes back the return,probably 60+ psi.
1slow96 is online now
post #4 of 7 (permalink) Old 04-02-2019, 03:23 PM Thread Starter
babywag's Avatar
Using a stock 5.3 regulator it won't go higher that ~50.
Thinking pump is weak or it has a max psi of ~50?
babywag is offline
post #5 of 7 (permalink) Old 06-06-2019, 12:40 AM
shudahadaV8's Avatar
So the pump can do more than 50 psi (brand new), but the regulator in our cars limits it to 40-ish. There is no reason to be at 50 psi unless you have installed some aftermarket injector that is spec'd to that pressure to get enough fuel into the cylinder for our cars ... racing, whatever.
shudahadaV8 is offline
post #6 of 7 (permalink) Old 06-06-2019, 08:40 AM Thread Starter
babywag's Avatar
This isn't an LT1 it's a 5.3 on a run stand stock LT1 FP assembly installed in a boat tank.
babywag is offline
post #7 of 7 (permalink) Old 06-06-2019, 04:43 PM
95wagon's Avatar
I might have missed you already doing this,,
Block return and see what it will pump dead headed?
The First
LS7 T56 6 Speed Wagon
Katech cam , 550 rwhp
11.79 @ 120.65
LS7 T56 drag video
My Wagon
My W-31 Cutlass
95wagon is offline
Similar Threads
External Fuel Pump into Stock Fuel Pump Harness bad_94_ss Electrical 1 04-02-2012 11:42 AM
Stock LT1 Fuel Pump HP support, and Max PSI???? killerzracing71 Engine Performance 15 11-22-2009 03:22 PM
how to max out stock heads. snakey5138999 Engine Performance 2 05-01-2008 04:17 AM
Where does the stock MAF max out at? 94SSman Engine Performance 3 11-09-2006 07:22 PM
DOES Z-MAX REALLY WORK? ssker1 Engine Problems/Maintenance 4 02-02-2003 07:53 PM
