So I just started my swap about 2 weeks ago and thought I’d share my progress for anyone that is interested. Basically done at this point, just need to head to exhaust shop and test drive the tranny a little more. But for anyone wondering how I did it and what you need:
Drivetrain: 2000 6.0 LQ4 with 4L80e pulled out of a junkyard GMC Sierra 2500 myself
Engine mounts:
Used KDS mounts and motor fit nice. Does sit close to firewall but not a big issue. You can slide them a bit and I did have the motor all the way back, but start at the middle. Replaced the stock motor mounts while I was there using anchor 2292 on both sides. Just make sure you have the correct orientation for the top and bottom because you do not want to have to take off the motor mounts over a simple mistake. And I was able to remove the mounts by MYSELF without having to drop the control arm. Just make sure you have a good swivel and flexible wrench and you can do it. Just take your time. And make sure to primer under the mount too before you put them on, if you are painting your frame.
Engine mounts:
