Doing brake system complete over-haul job, including replacing entire brake metal line with stainless steel one, 4 new rotors, pads, parking brake shoes, replacing calipers piston seal/booth and combination valve proportioning bolt and metering bolt mod.
Bleeding system is final step.
Looked up Caprice FSM, Haynes Manual and Chilton Book, no one mentions the engine should be ON or OFF while bleeding.
In reality, if the engine is off, the brake pedal can be pressed down only 1 time, the 2nd time pressing down will so hard like stepping on rock.
The engine should ON or OFF while bleeding?
Jesse
Jesse
