TPS and IAC questions...
634 views 3 replies 0 participants last post by  tbsimmons
#1 ·
How do you remove and clean, if at all possible.
Since I've been running my new PCM (T56, PP and all), the car like to bog down the RPM's on takeoff...even on idle, if I step on the gas...the rpm's dip and come back up.
Thanx people!!!
#2 ·
THe TPS cant be cleaned, it is mounted on the passenger side of the TB.
The IAC, can be.
It is mounted on the bottom. The TB will have to be removed to get it out. IT has 2 torx screws holding it on.
You will notice a bunch of black crap in it also. I use an old tooth brush and a rag to do mine, and it works great.
