Figured I'd make a thread here instead of continuing on the member introduction part.
Well, yeah, recently picked up this, excuse the terrible pic, after driving 7 hours in rain to get back home. I promise, it does look better when clean!
145k miles, so quite a bit, but the price was very right, and except for a few minor things. What was most important for me is as close to stock as possible and good bodywork/paint. The mechanicals I'm comfortable with fixing.
I work as an electrical engineer, but have a background as automotive service technician before I studied engineering, so the mechanicals are simple. Bodywork is on the other hand absolutely not my thing.
Will be driven in the summer, winter here is too harsh on an old car with road salt and all that. Plus, I have a master's thesis due next spring and have to spend time on that as well.
So far I have made a to-do-list:
- The brake warning light stays on unless I pull the parking brake pedal up. Guess it is just a small adjustment needed.
- I suspect the thermostat might be incorrect or not working correctly, might be operating a bit low. How high up on the gauge should the needle sit?
- Exhaust leak up front. Either manifold gaskets, manifold bolts or manifold itself, I guess.
- Instrument. Needs a cleaning and bulbs. Would love to find a 1996 canadian (metric) one, but I guess that's like hen's teeth nowadays.
- Finish replacing the steering wheel. Bought the car with a wooden wheel. It was nice in itself, but looked very out of place in this car. Going back to a leather airbag wheel.
- Heater knob is broken - does not do anything. I need to adjust the heat with the fan button. Probably just gonna get one in a junkyard or even new.
- Wipers. They work, but kinda slow, so I guess maybe the linkage needs some cleaning and lubrication to work better.
- Lights. The car was modified for Swedish regulations back in 1998 when it was imported. Today and in Norway, the stock setup is approved, and I will go back to this, just adding a relay for high/lows to get the most out of the not-to-good DOT headlights.
- Switch illuminations. Some things work, some things don't.
- RH mirror - seems like the mount is broken somehow, the mirror is kinda sloppy. Not the glass, the whole thing.
- Cooling fans - the original dual electric setup is gone, and I now have one tiny electric fan wired with the ignition, and a huge shroud for a belt driven fan, which I don't have. Will go back to the stock setup.
- Radiator is rotten at the bottom. Not leaking, but I don't want to be stranded with a blown radiator, so will replace this. Will do the AC condenser at the same time, as it's just as bad.
- Radio/speakers. Sounds terrible, and I'm not a hifi nut. Plus, I want Bluetooth streaming/handsfree.
- Brakes. Vibrating/pulsating. Need to have a look and see what's up here.
- Alignment. No uneven tire wear, but the steering wheel sits 30 degrees off when going straight ahead.
- Exhaust. The rear silencers have been replaced with straight pipes. Will put in silencers again.
- The white racing stripe wrap will disappear.
- Body to frame bushings. The car feels a bit floating, guess those are after 28 years and 145k miles past their useful service life.
- General tuneup with all oils, fluids, filters, spark plugs, spark plug wires etc.,
