My headlights are shot, one high beam and one low beam are out so i need new bulbs today, i was wondering if anyone has done the 100/80 watt EiKO's with the stock harness?
Bulb OUTPUT is measured in "Lumens" or Candle Power. Wattage is a measure of the bulbs current CONSUMPTION, not OUTPUT.Wattage output of the bulbs are not equilivent but actual thus higher current requirements and larger ga. wiring harness required.
What do y’all recommend if you know anything about h11 &h9Upgrading your headlights is dependent on the quality of the parts used and the quality of the installation. You need to use high-quality automotive parts that are designed to stand up to the rigors of automotive usage. These components must be resistant to chemicals (oil, gas and solvents) found under the hood of every car, a wide range of temperatures (underhood and ambient), weather (rain, sleet, snow, salt, etc.), severe and prolonged vibration, etc. It will pay you in the long run to select only products from companies with well established reputations for quality and durability; a bargain no-name relay could easily fail you when it decides to die on a dark road somewhere, leaving you with no lights. Do not purchase vehicle safety components based solely on price! The cost of premium hardware is offset by the fact that this will be a one time purchase and you may never need to upgrade in the future. I recommend Gary's Quad Harness with four isolated circuits - one for each filament. He has based this harness on the best components that he could find. For 9004 bulbs, the very best lamp is the Autoram 80/100 watt bulb. For H4 bulbs, the very best lamp is the NARVA or Candlepower 100/130 watt "Scorcher" bulb.
The stock headlamp electrical circuit, using lightweight, high resistance contacts in the switch, 18AWG wire to complete the circuits, and excessively long wire lengths (running from the battery to the dashboard and all the way out to the headlamps), creates excessive voltage drop. These wires are inadequate even for the stock headlamp capsule, much less for higher wattage. Headlight bulb light output is compromised with lower voltage. For example, normal engine-running voltage in a "12-volt" automotive electrical system is around 13.5 volts. At this voltage, halogen headlamp bulbs achieve 100 percent of their design luminous output. When operating voltage drops to 95 percent (12.825v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (12.15v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.475v), bulb output is a paltry 53 percent of normal! [Source: Hella KG Hueck AG, Germany].
Who cares? They work great and they don't bother oncoming traffic. Both the 2005 Toyota Matrix and the 2013 Tacoma have passed multiple inspections, so the inspectors obviously don't give a crap about them, either.Have a look at this video. With measurement the LEDs still do not match the correct filament bulb for pattern in a reflector headlamp. What no one talks about is the loss of light output as the LED heats up.
LEDs are not road legal in north america as each bulb must be tested in each reflector for DOT approval. The car manufactures and LED bulb manufactures have not done the certification testing on older cars.
