94 impala ss idling rough??? help plz
1 reading
1.7K views 8 replies 6 participants last post by  40767
#1 ·
Just bought a 94 impala ss and kinda purchased it knowing it needs some maintance so heres what its doing yesterday went to get a smog check done gotta do it since im in southern cali but neways so in the process of getting smog done the fuel pump burnt out so i had that fixed/replaced now the next issue is the car is idling rough when i come to stop at lights so this morning i replaced the MAF an had new plugs put in after i replaced the MAF the car feels like it has more power now but still idling rough an sputtering on take offs theres no check enegine light to run codes an oh yea the driver side exhaust has like a spouter sound like it has a cam kinda an when i bought the car it had a overheating problem so i bought a new therm sensor an bypassed the relay so a fan stays on all times so what else should i check or look into ? the exhaust manifold or fuel injectors id really appreciate the help thanks guys
an also it did pass the emissions test also
#2 · (Edited)
Read my post here: http://www.impalassforum.com/vBulletin/showthread.php?t=336177
The sputtering sound on the right rear of your motor is likely a broken exhaust manifold bolt - common on these cars. Search the exhaust section 'stickies'.
More hints
http://s368.photobucket.com/user/TheFooserGuy/media/ImpalaTuneUp-1of2.jpg.html?sort=3&o=59
http://s368.photobucket.com/user/TheFooserGuy/media/ImpalaTuneUp-2of2.jpg.html?sort=3&o=60
Also, go to 'User CP' at the left end of the blue bar above and add an approximate location (NY, LA, STL) in case their is someine in your area rhat might want to help.
HTH
#4 ·
You looked back in where?...You need to include as much info as possible, we suck at mind reading...at least I do. I bet you have several things going on. Did the fuel filter get changed with the pump? Before you screwed with the fans did they work as they were supposed to? How did you know the MAF was bad? Might have just been dirty. Sounds like you have the infamous broken exhaust bolt on the drivers side, The last one back by the firewall. If that is where you looked and saw a bunch of oil then the rear of the intake is probably leaking.
#5 ·
Why would you take it to be smogged when it wasn't running right? You do know what a hassle it will become if it fails a couple of more times, don't you? Make sure it is right before going on record again of another failure with the DMV. Put the fans back in correct working order. Good luck.
#6 ·
ok so heres todays update i took it to a mechanic an we found out that sparkplug number 3 doesnt have a spark so threw a diffrent wire in there an still no spark so i went to spark store an got a new rotor an cap an they gona do the labor for 200$ tommoro morning so i guess theres the answer for my misfire now with the oil leak havnt found where its coming from yet can tell if its from the vavle cover an leaking down to exhaust manifold or if its coming out the exhuast manifold now would that oil leak have anything to do with my performance cuz ima be pissed tommoro i had all that labor done for the distributer an its still running like crap
