here is the issue on my 95 impala ss....
The car has enough anti freeze. I replaced the thermostat, water pump sensor (to the bottom right of water pump), primary and secondary fan relays, and the fan fuses are good... Also there is NO LEAKS in the system anywhere.
Now here is the issue. When the car gets hot, OBVIOUSLY the fans are supposed to turn on. At least the Primary one first. It doesn't. The car just over heats. Now, if i am driving the car and NOT just sitting at idol, the car is cool because of wind hitting the radiator, and i also have the heat running all the time.
Here is the weird thing. If I unhook and take out the WATER PUMP sensor, the fans both come on as soon as the car starts. My guess is because the computer thinks the car is running at 4 million degrees and is in panic mode. This is also the reason why when that is unhooked, the car takes 15 seconds to start, and the reason why i get 10 miles to the gallon. The computer is telling it to dump way more fuel into the motor.
I am now lost... someone help me, please !!! Is there another sensor that i am missing here? Everything in my eyes besides the water pump itself, has been replaced.
