Hello ,
im planing to ls swap my b body 96 impala ss , i got ls1 engine with trany
from junk yard and will be rebuilding both ,
i have some questions and concerns and i will really appreciate any inputs and help ,
1. perfect oil pan : problem with muscle cars swap oil pans is they mostly hang below the crossmember , my car is air bagged and i can't have that , i will be useing dirty dingo mounts so which oil pan will be most fit ?
2. which headrs ? : which headrs will be most fit for this swap ? i have no problem cuting the frame or the crossmember for slight adjustments , and what size should i use with a stock ls1 ?
3. oil pump : should i use an aftermarket one such as milling to avoid any future pressure problems ? if i do which one it will be for a stock engine ?
i read so many threads but i did not find a good answer especially about oil
pan
thanks guys ...
pan
thanks guys ...
