The SLP's I have been running in there for at least 10 years are thinner than ACDelco stockers, but they definitely aren't much "newer". There is a support clip (c-clip) at the bottom of the injectors to prevent them from going too far down into the port. They have never leaked to this point. I have interest in this topic again because I just replaced the O-rings while I had the fuel rail unit out for a new fuel injector regulator. The compression of the 4 bolts that tighten down the fuel rails keeps the injectors firmly planted with no potential for vertical or lateral movement. If there was a leak it would be due to an O-ring being torn or compromised. I'm keeping the valve covers off for awhile so I can continue to monitor the fuel injectors for any leaks with the new O-rings now in there. I also installed a Dorman nylon fuel line coupler and connector on the 3/8" sending line from the tank because there WAS a leak in the stock metal connector due to the torn-in-half orange O-ring inside. The nylon pieces look rather chinsy, but the ratings and most all of the reviews reported good results. So now I'm always sniffing around the rear and front of the car whenever I finish driving. Safety first!
