Hello all
I seem to be having a fuel pressure concern. The car is a '96, all stock and all original. 26k miles and a new fuel filter. It has had longer cranking times after an overnight sit. 4-5 seconds, and occasionally a second try, but on the second, it always fires right up. Hooked up a fuel pressure gauge after sitting overnight. Turn key on to energize pump, get 30 psi. While crankng engine, gauge reads 20-25 psi. After start up, gauge reads a steady 40-1 psi. The car runs fine. After shuttig off a warm engine. if you energize the pump, the gauge reads 40 psi consistently. Presasure bleeds down to zero after about six hours. Car seems fine after the first start of the day. An help is appreciated. TIA
CDK
CDK
