Let me start with a full disclosure; I do not own an Impala. I have a 1993 Roadmaster Limited. I joined this forum a while back because there is nothing that comes even close to the knowledge base here for my Buick, so any help would be greatly appreciated!
I do have a used FSM on the way, but it won't be in time to get me to work tomorrow morning.
I have tried searching but have found nothing close to my situation.
I started my car and noticed that the headlights (and all running lights) came on by themselves. When I parked the car, I dsconnected the battery, reconnected it, and the headlights were off. When I turned the ignition switch back on, the headlights immediately came back on. Disconnecting the battery reset everything and the headlights remain off until I turn the ignition back on. Turning the ignition off does not turn the lights off once they are on. The only way they will turn off is to disconnect the battery.
This makes me think that I have a short somewhere between power through the ignition switch and the headlight relay. However, my problem is that I am working blind without any wiring diagrams, and I need the car working correctly by Monday AM.
Scans of wiring diagrams, or a color code legend would also be appreciated!
Keith
Keith
