"Does anyone know if Global West has ever considered making a full set of lowering springs? I know there front springs may lower .5", but have they ever mentioned a full set that would lower an SS 1-1.25". Also, if the front suspension camber gains were fixed to be optimal, could it be possible to see 1.xx g's on the skid pad? "
Ed Runion's reply:
No they haven't, for a good reason. And this gets into why my car isn't lowered much either.
Namely, the
suspension has a "sweet spot" geometry-wise where it works best. And, not surprisingly, it is pretty close to stock SS height.
BTW, the GW front springs basically don't lower an SS at all.
I don't think you'd see much cornering gain (maybe a little, but not lots) with the modified control arms versus a stock parts alignment that is "handling oriented". The real gain (IMHO) of the modified parts is that you'd be able to get the better handling WITHOUT having to run an alignment that is detrimental to tire life to do so (i.e. case on my car right now : handles great, but I'm not setting any tire life records)
"LOL, yup Ed's setup is Top Secret, "Eyes Only."
Off the top of my head;
T56
F-Body front bar/slightly stiffer than stock rear bar(seriously)
GW front springs/stock rears
GW rear lower arms with DelAlums/aftermarket uppers(rubber bushings?)
GW DelAlum FCA bushings
HAL QA1 shocks
"Sport tuned" alignment
Torsen T2R "
Ed Runion's reply:
"Only thing that Wayne missed on my setup (and it DOES make a big difference) is that I am running 275/40R17s on 17x9.5" in front and 315/35R17 on 17x11" in back. Even just going to 17x9.5" all around with the same exact tire as on a 17x8.5" rim (i.e. same 275/40R17 on either rim) will help a good bit."
Anyone know the lateral acceleration(g's) of the stock suspension on our cars? Also any specs for the skid pad of a modified suspension?
www.impalassforum.com
So, lowering is probably not on my list
Navy Lifer:
"So, lowering is probably not on my list--if you were building from scratch, that could be factored in, but the suspension points, wheel travel, suspension geometry, wheel openings, etc limit how far you can or should go in the lowering department--just for the sake of making the car lower. Yes it looks cool, but first & foremost,
there MUST be adequate travel for the suspension to work properly. Lowering puts the front suspension, especially, in a situation where the geometry is at it's outside range of acceptability (or beyond) and IF the outside front position bottoms out, the available traction at that corner basically goes to zero.
Better to up the rate on the front springs to ensure travel at high loads,
keep close to standard ride height (for all the reasons mentioned above), play with the different bars you have mentioned, and then work on an ideal alignment setup to dial in the car.
Do not assume that a rear bar is essential for the car to handle well--increased front spring rate will help reduce camber change from chassis roll (which drastically changes total tire contact patch). Some additional front spring suggestions include Moog 7268 (750#) and 7270 (800# +)--ideal to work with this would be a re-valved AK1053, or the street adjustable Koni's, but, again, there are the budget/rules consideration(s).
Stock SS rear springs are a good starting point--OE spec is 154#, I recall. The Speedway springs may actually lower the rear, but that can be corrected with spacers, or perhaps accommodated in the acceptable range from stock ride height springs--just remember that lowering the rear will also have an impact on what the front alignment settings are.
For the money spent, good shocks are one thing to focus on, but not understanding the full budget limitations, I can only say do the best you can.
The other consideration with lowering the car is that shock length relative to total suspension travel does matter--and ideally the shocks will be at mid-travel with the car static. Lowering the car any significant amount creates some potential for bottoming or damaging the shock(s), which is not good. If the car is to be lowered, either new shocks with extended & compressed lengths to accommodate that change should be sought out, or the mount(s) may need to be modified to restore the shocks to a mid-travel position. At the very least, check the shock travel against suspension travel to determine whether there IS a potential travel issue.
I don't think it would be economically worth the effort to try to work out the Ackerman issues--if this was a full-out race car with race tires, the grip level would make that important, but with the weight of the car, the size and type (I assume DOT street-spec) tire is going to result in wheel-slip rates that would not change significantly regardless of the situation with the Ackerman effect.
I would take a look at the steering gear to see what can be done by way of bracing to stabilize the left frame rail--it's an interesting thing to watch the gear move even while static and see it "walk" back & forth with steering wheel inputs--not dramatic, but imagine how much it might move under dynamic load conditions. "
Well you would be surprised at how well you can make it handle without lowering it.
Hi Guys- new here and have been researching posts for some time trying to determine suspension setup. I have a 1995 9c1 that I race in the 24 hours of Lemons series. I've run a couple races now and would like to get her to handle better, lower CG, & save tires. The car is gutted and...
I just wanted a few respected members to quote as counter point the opinions of the best handling is at the lowest suspension level.
