LS swap oil pan?
1 reading
16K views 26 replies 8 participants last post by  96Jaden
#1 ·
What's the most common used pan and mount combo being used on swaps? I'm thinking about getting kds mounts and f body oil pan?..What do you guys think? Thanks
#2 · (Edited)
I am currently using a Holley 302-1 GM and it fits great with energy suspension SBC mounts, the pan fits the cradle just like the 350 pan did. I was using the GM muscle car oil pan but it hung to low and my wagon is lowered. Sorry my phone keeps uploading the pics upside down. One is of the Holley from the rear and the other is of both.
#3 · (Edited)
What mounts are you using? I'm using KDS mounts. I used a factory F body pan I purchased from Improved Racing then purchased their baffle kit for better oil control. It fits great, no issues.
the baffle kit is a must for the F body pan IMO if you are making any real power. F body guys have lots of data on LS1 tech of pretty significant oil pressure drops caused by starvation upon acceleration on cars that were cutting decent 60 foot times (we're not talking about only 9 second cars here).
I talked to Improved Racing about the baffling on their F body setup vs the Holley with optional baffle kit. turns out they were contracted to design the trap door kit for the Holley pan so the only real difference were pan dimensions.
Since the holley pans are similar in shape to the F body pan, I would imagine any oil control issues an F body pan would have, the holley pan would have too. When you add the optional baffle kit with the holley pan it comes out to a bit more $$$ than the F body pan with Improved Racing baffle kit which is why I went with the latter.
You could probably ignore all the oil control stuff if you're just doing a budget LS swap with 400hp or something.
#4 ·
I'm planning on kds mounts...Car has a 6.0 swap already...But has a modified truck pan that has seen better day's...Transmission is from the donor truck also..Oil pan is close to suspension, and transmission crossmember hole has been slotted for trans mount to line up...Almost like engine sits a few inches forward...Hoping kds mounts can remedy this?..
#8 · (Edited)
If you are planning on swapping to KDS mounts, the mounts were designed to work with the F body pan so that will work fine. The holley pan also fits so it's just a matter of preference at that point.
Just keep in mind that a lot of LS swaps I've seen with adjustable mounts place the engine a decent amount forward from where the factory drivetrain would have sat. The KDS mounts retain the stock drivetrain angles, engine placement (front to back) crank centerline height I believe which to me was a big selling point because I don't like the idea of moving the single heaviest component of your car even an inch more forward or higher than where it was before. Issue with this is if you swap mounts, there is a good chance your current headers may not fit and you may run into some other minor clearance issues from the change of positioning.
As far as the slotted X member goes, this is more than likely because of the mounts you currently have, and with the KDS mounts you should be able to run a factory crossmember IF you are still running a Gen2/LT1 4l60e. I swapped over to an LS 4l60e and the trans mount position was WAY further forward than the LT and I had to do some extensive modifications to my tubular X member.
Another note, KDS mounts provide 3/8ths of wiggle room by having slotted holes to account for chassis to chassis variations. To clear the F body pan I had to run my motor in the furthest to rear position. Aside from some clearance issues I had to address with my LSA supercharger and tall style valve covers, everything fit fine and this actually helped give me a little more clearance to the K member of my 1 7/8ths TSP headers.
Depending on what headers you have now, it may just be easier to find a pan that works with your current mounts rather than risk running into header clearance issues and possibly AC compressor clearance issues by swapping to KDS mounts. KDS mounts work great with a very specific part selection (F body pan, F body headers, truck accessory drive) but if you don't already have all of that, it could be troublesome to switch over to them. I can't remember if a truck AC compressor clears without notching the chassis either, you may have to run a mini compressor.
#6 ·
#11 ·
With the compressor up high, I can't see you having a problem but you may want to check with KDS first about the alternator clearance as the KDS mounts will be changing the height and forward to back positioning of the engine.
What headers do you have now?
#12 ·
Ray…..I do have a new F-body pan that I won't be using.
PM your email for pictures.
KW
#19 ·
Without wading into the "is a 10+ Camaro an F body?" pool,
I think when most speak of LS "F" pans, they're are refereing to 98-02.
KW, doesn't your SS have the great long 9 quart pan that my G8 has?
Think the same as 10+ Camaro?
Cant see that fitting a 94-96 impala.
#20 ·
#22 ·
You and I are on the same page.
Interestingly, there are - were couple 09+ g8 ss pans......
Yeah.....I think just the GTPs.
BTW....your LS7....what oil pan are you using?
KW
#25 ·
So your stock 2014 Chevy SS pan fit in the impala?
I'm getting crate engine part # 19370416, which comes with the Chevy SS oil pan. Looking at the picture of the pan in the picture, it doesn't look like it will fit. Did you cut your cross member?
#26 ·
