It's not hard to use the brackets with Hotchkiss LCAs. You just cut off the rubber and replace with the aluminum bushings. Mine are welded and bolted. My LCA angle is now 5 degrees up from rear to front (was parallel before).
What these brackets do is try to RAISE the rear on acceleration. As your rear goes up, it puts an equal and opposite force, planting your tires harder. The ideal situation is to have the whole car rise parallel to the ground. This will give best traction. I was always able to dead hook at the track, with never any tire spin, down to 1.72 60' time on my drag radials. I never shot N2O right off the line, otherwise I probably would have some 1.6s.
I'm finding right now that what I thought was tire spin with the new 3800 converter, was in reality just loss of torque due to the new cam, and 2.54 first gear. At the track this Saturday, I'll shoot N2O right off the starting line to make up that loss, and expect to have no spin at all and get back to lo 1.7s.
No sway bars, one air bag at 20lbs on the right, Hotchkiss LCAs, Metco IC Brackets and front HAL shocks set at 0.
I believe the reason guys like Keith have such excellent 60' times is the tremendous torque they have down low on those strokers. If you can get enough power right at the instant of takeoff, then due to body movement, the tires plant much better and hook.
