Hi all - still working on this 94 Fleetwood. Finally got another transmission in it and can now address the air conditioning problems it developed right before the transmission went out.
Since the compressor was failing and then one of the hard line/hoses cracked, I decided to get new hoses, a condenser, and a compressor kit from Rock Auto, all UAC brand. In the compressor kit was a new Korean manufacture compressor, which indicated it should be used with PAG 46 and that it indeed was already filled with the appropriate amount. I recall that the factory compressor wanted PAG 150. I'd just like to confirm that there's no problem using PAG 46 with the rest of the system - I can't see how there would be, but I'd like to check. Thanks.
