Removing tire from rim at junkyard?
2 reading
5.5K views 13 replies 12 participants last post by  etc.
#1 ·
I have a shot at getting some 9c1 rims from the u-pull it yard. Problem is, they are still on the car with the tires. They want $7 for each rim, but I would also have to spring 15-20$ for each tire. My question is if it's easy or practical to remove the tire while there to save about $80. Once it is flat, is it pretty easy to pop off the rim? Any help is appreciated.
#2 ·
No, it is not easy or practical. Have you never mounted a tire? You will damage the bead of the tires trying to do it yourself and will end up having to buy the tires as a result. Either have the yard un-mount them, buy them with the tires, or find another set of wheels. Good luck.
#4 ·
the hard part is breaking the bead loose.
without knowledge and the tools, doubtful.
you could take a tire mallet, couple of tire bars and some spray soap and do the job if you knew how or find somebody who does.
#10 ·
ALso, using a sawzall or cutoff wheel to remove a tire WILL make a cloud of smoke that looks and smells like a mile long burnout.
#11 ·
