Have a 94 Roadmaster with 78,000 original miles, always maintained and garaged. Started having some slightly rough idle, and surging or hesitation at low speed. Ran a fuel pressure test with an OTC FP tester and got 45psi spike, key on engine off, then immediately settled to 36psi. Started engine, spiked to 45 again, then settled at 36 psi running, revving engine it would spike to 46, then spike to 34 for the next rev, then settle at 36 psi running. Shutting off engine it would be at 35psi.
(These numbers are with engine off below)
Then after 5mins it would climb to 43psi.
10 mins still 43psi.
20mins 42psi
30mins 39psi
40mins 34psi
50mins it would climb to 42psi
60mins 41psi
70mins 36psi
80mins 32psi
90mins 28psi
Not sure what to make of it. No leaks at the vacuum hose on the FP Regulator or gas smell. No smell of gas from leaking injectors at the Throttle body. Injectors Ohmed out all at 12.8-13 ohms. All hoses inspected for cracks and leaks on engine and tank and Charcoal canister, checked and cleaned all grounds, replaced EGR with stock and F1 version, no change, EGR Control Valve tested out at 1020 ohms, new fuel filter... only thing I havent done is drop tank and replace Fuel Pump as it seems to get 45psi spikes.
Anyone have any experience with this? Thanks in advance to this great forum.
20mins 42psi
30mins 39psi
40mins 34psi
60mins 41psi
70mins 36psi
80mins 32psi
90mins 28psi
