Upper control arm angle and anti-dive?
757 views 2 replies 0 participants last post by  kevm14
#1 ·
I was reading up of race car suspensions and I read that if the front upper control arms are angled front to back a few degrees(higher in the front), instead of being level with the chassis like the lower arms, the car will resist weight transfer to the front, and dive less under braking. Can someone explain the physics of this to me? Could it be applied to our cars? What if the LCAs were angled back like the uppers? What affect would that have? Thanks
#2 ·
To be overly simplistic you are modifying the path the susp takes so under braking the spindle tries to move down.
You will note the “B” car upper is not level to the ground already
There are a couple of ways to look at it, well probably 20, with anti dive if you force the wheel back if it will try move down.
Also with brake antidive if you twist the spindle back on the bottom, forward at the top it will rotate down.
By slanting the back of the upper control arm down this causes the upper ball joint to move forward as it goes down. As the brakes try and turn the spindle forward, it will pull down.
If you dropped the front way down but also dropped the front of the lower way down the resistance of the spindle while stopping would pull it back and down creating anti dive as well.
There are a billion interrelated factors that all get affected so it is not a matter of just tossing a wack of anti dive in.
One directly related thing is the car becomes incredibly harsh with too much.
It has been years since I have worked with changing arm angles and I am sure there will be guys here that are much more up to date than I.
Gerry
#3 ·
Doesn't it also put a lot more stress on the ball joints, control arms, bushings, frame mount points and whatnot?
I don't think these cars are all that bad for brake dive. Especially considering when all these geometries were engineered. There are a lot of cars with far more recent engineering that dive worse. My Camaro is one that comes to mind.
