what torx bit size to remove seatbelts?
2.2K views 9 replies 0 participants last post by  MK Tribbie
#1 ·
this is for a 96 SS if it matters, thanks in advance.
#10 ·
...use a 47 or you risk stripping out the bolt head. A larger size bit might 'seem' like it fit's, but it does not seat all the way down in the bolt head. You don;t have all the Torx tool surface against the bolt head surface and if the bolts are tight, you will strip them.
