I changed my optispark and replaced my water pump not that long ago like 3 months not aftermarket parts I noticed my car over heats now what would be the proper way to bleed the cooling system
Wrong t ? Fans are working i notice the the driveshaft that connects to the water pump was not spinning andand it over heats then it spinning and it don't over heatYou replaced WP twice now??
if so its either a bleed issue, wrong T stat (needs to be LT1 specific), fans not working or your radiator is F'ed
You should not be able to turn the impeller my hand while it's installed on the engine.Wrong t ? Fans are working i notice the the driveshaft that connects to the water pump was not spinning andand it over heats then it spinning and it don't over heat
Wait... can you re-word this into something my coffee-addled brain can understand? Are you saying the shaft doesn't spin while it is running and then suddenly starts spinning on its own?i notice the the driveshaft that connects to the water pump was not spinning andand it over heats then it spinning and it don't over heat
Yes exactly what I saidTo answer your original question about bleeding air, use a vacuum-fill coolant tool. They're cheap - I think HF even sells one now.
And I'm not able to turn it by hand i even took the cover off the wp to see if it propeller moves while I crank the engine and it does put it all back then it work well and all of sudden I'll give it gas and It will start getting hot again and wp stops workingYou should not be able to turn the impeller my hand while it's installed on the engine.
That's what I'm thinking so I ordered a new coupling hopefully it's fixes my headacheSounds like it is slipping somewhat, and that's never good.
Just in case, somebody please show a pic of the correct orientation of the spline key sleeve between the engine & the H2Opump.That's what I'm thinking so I ordered a new coupling hopefully it's fixes my headache
I double checked that side that has a grove around it goes towers the block and smoth side to the wpJust in case, somebody please show a pic of the correct orientation of the spline key sleeve between the engine & the H2Opump.
It's been installed backwards too many times.
That's what I'm thinking I'm just going to trying with a new coupler I ordered ti see if it fixes the issue if not I'm going with ewp any recommendations of videos or step by step instructions on how to do it ?the O rings mentioned go on both the WP drive spline and WP spline to "stabilize" the coupler from vibrating...typical cause of WP drive seal leak
There have been posts of people having worn/stripped splines in the coupler which can cause what OP is describing. If the splines on the WP drive gear are also worn/stripped...the shorter path would be go EWP as replacing that gear and drive is a big job. The gear can just be left in the motor with EWP
Did you remove the shaft coming from the block ?
I found this helpfull. I can't remember, and I'm not able to re watch this at the moment, but I seem to think they used a hammer to push out a peice. I definatly needed a press. Hammer was not getting the job done.
Yeah , I saw no functional difference, just ease of assemblyJust in case, somebody please show a pic of the correct orientation .
No, just the coupler. The shaft is back there spinning away.Did you remove the shaft coming from the block ?
Yea I was going to say because if i have to remove the timing housing I rather just fix the problem lol. Did you have to used a hydraulic press to remove the parts from the water pump ? Or did you used a hammer 🔨 🤔 and a screwdriverNo, just the coupler. The shaft is back there spinning away.
Looks like they did use a hydraulic press in this one.![]()
I see did used a hydraulic press to remove the inner components from the wp or did you used a hammer 🔨 and screwdriverNo, just the coupler. The shaft is back there spinning away.
