So I have done quite a bit of research on this. I am looking to run the Torqhead system. I watched all of Rubber City Motoring’s videos on the subject, and it looks like its so easy a Caveman could do it, and it seems to work flawlessly.
i have a 2000 4l80e from behind a gen vi bbc that came out of a gmc 3500 flatbed that I want to throw in the Impala.
the 4l80e conversion harnesses i canfind are listed as being for 98 and up F-bodies, but also 1996 and up trucks.
i know for the B-body the 1996 got all pf the latest improvements, and its a 13 pin connector. From everything I have researched, it should be exactly the same as the 1996 vortec 4l60e from the trucks with the possible exception of the tailshaft design, but same vss, same 13 pin connector etc.
Does this mean that I can use the same conversion harness as a 1996-2000 gm truck would? I know I’ll have to make some programming changes (or request them in the tune from torqhead).
also, I know there is a sticky thread on rewiring the 4l80e to run off of the lt1 computer, butI’m looking for as close to a plug and play solution as possible.
