change oil every 12 or 3 months?
2.7K views 10 replies 8 participants last post by  SoCo80P
#1 ·
ok so for the most part i had always been told you change the oil every 3 months or 3,000 miles.... but i was browsing the caprice manual and near the back it had a list of what to do every X amount of miles as far as maintenance goes. near 30k miles it said change the oil every 12 months or (whatever the amount was) miles.
should i change the oil every 12 months like the manual says because its still at 30k miles, or stick to every 3 months because its a 15+ year old car?
#2 ·
I wouldn't do that. I changed my wagon's oil every 5000 miles or whenever the oil change light came on. My wagon had 275,000 miles on it whenethe bottom end finally let go. And I beat the hell out of that car.
How often do you drive it?
#3 ·
Back in the 60s and 70s, changing it twice a year or 5000 miles was the norm, and should be sufficient. The interval for mileage is determined by your driving conditions. I believe it says 3000 for heavy (dirty area, towing, stop and go) use, and up to 7500 for light use (highway, minimum stop and go). If it leaks/uses about 1 quart a month, you probably can get by with changing the filter every 6 months, and just adding oil.
#4 ·
hmm... it's my daily driver so I drive it every day. I don't travel too far though... usually within a 3 mile radius from my house. everything I need is within that distance thanks to livin in the city
#7 ·
You really need to drive it on longer trips. The engine should be up to temp (in closed loop) for at least 5 minutes, on a regular basis, to cook off volatiles in the oil, or the viscosity goes down. You are probably in the 3000 mile, or twice a year club.
#6 ·
If you use standard oil, "ole" for those south of the Mason Dixon (snicker snicker) I would change my oil 3,000 for short local trips (tough on the motor). If you use synthetic I would go 6,000 for the same conditions. I do mostly highway and I USE my LT1. I put Amsoil Signature Synthetic oil and do a filter change at 6,000, changing the oil at 12K.
#9 ·
Ditto Fred on this one^^^^
Where in Palm Beach are you at? You should start running it down to Tower Shops every once in awhile. Always nice to see another B-body enthusiast near by.
I have a little English sports car that I put about 1000 miles annually on. I do the oil once a year in it, as it's rarely driven.
On my B-bodies, the RMW, I do when the oil light comes on, which is usually about 5K, although sometimes, it'll come on again 1000-1500 miles later again. The oil is then dirty and I change it out again.
On my other not so well optioned cars (aka the 91 Olds), I do it about every every 3500-4000, or if it looks really dirty.
I have checked oil at 4K and had it still be translucent, so I might let it go a few more hundred, if I'm busy and don't have time to change it.
All depends on the type of driving you do.
