My question is what is the difference between “uncoated” stainless steel and “coated” stainless steel, and what did you guys go with, any input is appreciated. My main concern is rust. Thanks in advance
For a regular street car/daily driver, the main difference will how much lighter your wallet will be.
You noted your main concern is rust, so 304 will be fine for that. But coatings can also help dissipate heat, and is one of the reasons a lot of people opt for the coatings.
Like he says, rust will not be an issue with 304. Factory in many cases has used the lesser grade 409 stainless. They start to 'look' brown like rust, but they're just fine. The factory exhausts on our cars are a 409. Still have the original on the '95.
As far as heat, coatings do not help dissipate, they actually help insulate to get the heat to keep going down the pipe and out the back. And to keep underhood temps lower. And as far as street car, you're not going to be generating anymore heat if the rest of engine is stock. And even if it isn't, on the street, the time you are actually making more heat relative to the rest of your driving would still be negligible.
I've run all variants over 30 years on the mustangs. Nickel plated, coated nickel, plain, coated plain, and finally ebay polished stainless. Those are still on the 85. Probably 20 years, geesh time flies. Other then the heat discoloration, they are just as sound as new.
So IMHO, if you're going for the look, go coated, but that coating as you hear others, still doesn't last more than several years. None of mine did. (in a snow climate) If you just want ones that will last the car, plain 304 stainless will be fine.
