to make a swap4l80e into the 96 caprice /my motor is ready and ill like to use a 4l80e tranny i hear they are strong trannys. what do i need to make this swap happen?
What do we need to do because of that?Don't forget the '80 has 2 speed sensors
Tunercat definition file $EE CY is required for this... http://www.tunercat.com/pdfs/pcm_$ee.pdfhttp://www.camaroz28.com/forums/com...ter-diagnostics-tuning-36/ecm-configuration-file-version-cv-723618/#post6183526
Yes, for the 4L80E the switches should be set as follows:
X Shift Solenoid A - 1st Gear (X=Enabled)
0 Shift Solenoid A - 2nd Gear (X=Enabled)
0 Shift Solenoid A - 3rd Gear (X=Enabled)
X Shift Solenoid A - 4th Gear (X=Enabled)
0 Shift Solenoid B - 1st Gear (X=Enabled)
0 Shift Solenoid B - 2nd Gear (X=Enabled)
X Shift Solenoid B - 3rd Gear (X=Enabled)
X Shift Solenoid B - 4th Gear (X=Enabled)
Is that an OBD2 PCM or an OBD1 conversion PCM in your car? Do you think that OBD1 vs. OBD2 would make a difference?So far I'm please with how well the LT1 PCM controls the 4L80E, and I'm happy that it didn't require the use of a relay to make it happen. TunerCat to the rescue!
It's an OBD-1 conversion. I hope that it works just as well with an OBD-2 PCM, because I'm planning to buy the DST kit from Jet. I just wanted to make sure this would work using the tuning software I already had on hand before plopping down another $400.Is that an OBD2 PCM or an OBD1 conversion PCM in your car? Do you think that OBD1 vs. OBD2 would make a difference?
4l80 vs. 4l60 vs. 200r4so why is the 80e not a good match for highway driving? I'd think that the higher amount of gears would drop highway rpm's nicely, especially for cars with rear end gear swaps. It'd be nice to not be spinning 3000rpm cruising down the highway.
I don't think you want to follow the instructions in that image.Thanks for all the help, I just made a deal on a 4L80E that was too good to pass up so I will be doing the 4L60e to 4L80e swap.
Just to make sure I have this covered, I have to
-flip the logic for the shift B solenoid with tunercats
-move the U brown wire into the S position
Is that all that is needed to make this work?
I understand I will need the 168 tooth flexplate and new starter to match.
I think I only had to move that one wire to position "S".... and Nab was correct about moving the PCM_C4-11 (Transmission TCC Solenoid) Tan/Blk wire to position S in the trans connector.
I don't remember, but I thought I mentioned above that it's what I did. I really don't have the time to go pull the connector off and check. You could ask Blue Wail. He's also running a 4L80E with the stock PCM.RatSSled, did you use the single wire "TCC ON/OFF" to control your lockup?
also did you do any tuning due to the first gear difference or anything else trans related to the swap?
Can someone please confirm this?
Also, Nab tells me that you have to move the tan TCC wire to the 3-2 downshift wire. Does that mean that you simply move the Tan wire to the 3-2 downshift pin hole? If so, is there no wire already there, and if something is there, then what are you supposed to do with it?
Finally, is this all that is needed? What other tuning changes should be or could be made to make the 4L80E work best?
Some reference links: http://www.msgpio.com/manuals/mshift/4L80E/4L80e.html#settings
I looked at the TCC tables, and I don't see why it was locking so low like it did. I also need to find out which tables control the TCC in a 4L80E. I think I read that the 4L60E has two TCC signals (on off and PWM), whereas the 80E only uses PWM. The good news (temporarily) is that I don't need the TCC to race the thing! But I do need it for the street, and it's still a street car.
I'm almost finished with the job. The only thing left is to sort out the TCC lockup. Everything else seems to be working perfectly. Other than the changes to the switch table for the 4L80E solenoid pattern, I've pretty much kept all of the trans tables the same as the 4L60E. I only changed the shift RPM's and cut the normal mode shift times in half. It shifts perfectly and I like the faster shifts. I think that it drives better with the LT1 computer than it did with the PCS TCU.
So about the TCC. I had originally moved the Brown wire from U to S. On the first test drive it was locking the converter way too soon, as if it was set to lock at too low a speed. So I decided I must have swapped the wrong wire. So I then moved the Tan Black wire that was in T to S, which is the one Nab had told me to use in the beginning. However, now I don't get TCC at all. I guess I was right in thinking Nab was wrong. Anyway, I'll take a closer look at the bin file to see if the TCC tables are goofed up. If so, then I guess I put the brown wire from pin U back into pin S and adjusting the TCC tables.
Good news, the TCC lockup is working, and Nab was correct about moving the PCM_C4-11 (Transmission TCC Solenoid) Tan/Blk wire to position S in the trans connector. The reason I didn't have TCC lockup the first time I test drove it was because I didn't let it get up to operating temp. It was below freezing that night and I was being too cautious about running an untested setup to far from home late at night. Tonight I took for a much longer drive, and it definitely locked up this time. I felt it lock, and I have a DM log that shows it.
Also, using the TCC Enable signal is just one of the ways to do this. Thanks to the efforts of brilliant minds over at EFI Live, there is another option involving a relay that lets you use the TCC PWM signal to pulse the TCC PWM Solenoid, Link ---> link. It requires that you use the TCC Enable signal to latch a relay that drives the PWM signal on the S position at the Trans connector.
Now how would I know?Thanks, I found that my $EE file is downlevel, that is why I could not find the shift tables. Working on getting that updated now.
How harsh is your lockup using the ON/OFF rather than PWM control?
