I've been looking to upgrade my brakes on my 94 impala ss. Seen a couple different brands and I'm leaning towards the power stop z23 kit but I'd like to know everyone's input on it and what do you guys recommend.
Well, I mean, no.All PowerStop rotors are slotted and/or drilled
You're killing me Michael...."infamous"???I would say to upgrade to the infamous HD12 kit from Bill Harper, but we know that is no longer an option.
YMMV
Michael
Unless you are racing or driving in the mountains the best brake upgrade is better tires.How do you define "upgrade"?
Have you tried these? The hats are for 8x7 rotors. And those rotors are 8x7.05.The HD12 kit isn't dead, you can still build it using Wilwood components. The part numbers are:
Aluminum hats: 170-0764 (need 2 of them)
Right rotor: 160-16027 (need 1)
Left rotor: 160-16028 (need 1)
The point of the brake pads is to stop the rotor from moving, right?In no cases do drilled holes or slots provide any added stopping power from a perceived "bite" into the pads, even if you might feel those features through the brake pedal. Stopping power is purely a function of the coefficient of friction of the pad (which varies based on the pad's temperature and compound), how hard it's being pressed against the rotors, and what leverage advantage the pads have against the rotor.
Post your best pad choices as there are bad ones (usually cheap).
Columbus, all well & good - what size wheel is necessary to clear the caliper? Anything that large is usually going to be 18" minimum. I acknowledge that there is room for 350mm rotors with fixed calipers (shorter bridge height) to fit inside the barrel of the Impala SS wheel.Mercedes DF4541S / A2204211212 / 09.9463.11 360mm disks machined to 350mm. Calipers mercedes too.
This post accomplished nothing.Single event or not, how do you push against empty space? And expect there to be friction?
Put your palms forward while standing, and lean forward...![]()
You sure, bud?And no, the edges are not adding friction.
Yup.Heat is one thing, and single-event braking is another.
I know the big brake setups really shine when used for repeated hard braking (i.e. racing and autocross situations) but better stops than my 116 feet for 4700 lbs. of loaded down 255/285 F/R Potenza shod beaSSt with stock brakes
Well at Waterford Hills during dreamapalooza I hit just over 90mph on the back strech.... I didn't brake until I came close to the 100ft marker.. And I made the 90 degree turn with minimal sliding. So it would have been about 90-0 in about 150 feet. Stock rotors up front with the ACDelco ceramic pads, Power Slot rotors in the rear with Brute Stop pads. I ran the Valvoline synthetic brake fluid (Good to 500+ degrees) and Russel Stainless Steel brake lines at the calipers. I had switched to the Civie front Calipers from the 9C1 that I had.
The forum is full of brake modification posts. I have not found any before/after modification measurements.I too ran Waterford, and the STOCK brakes were good enough to get me a 6th in the modified class - bested only by the likes of Harvey Clark (Purpala), Chuck Spera (fastest at Y2K), John Madeley (Giant SS), Ed Runion (you know ED!) and Bob Fandetti (Pirate ship racing). I consistantly ran faster lap after lap with the Stock brakes smoking!! I have also ran for a 20+ minute circuit on a roadcourse with no appreciable fade. So my contention is that the stock brakes aren't all that bad.
The "big brake" approach is to raise thermal capacity, which allows brakes to be more effective for an extended period. That is why larger OR thicker rotors are really what offers better baseline performance. Look at the growth of wheel sizes AND brakes for numerous vehicles introduced since 1996, many that are smaller & lighter than Impala SS & 9C1. Some of this is by way of Federal brake performance mandates over the years since the 4-wheel disc system used on the 94-96 B platform, as well as marketplace imperatives.The forum is full of brake modification posts. I have not found any before/after modification measurements.
In day to day driving the best brake pads and tires may be the best use of someone's budget.
