Hey, does anybody have the FSM specs (or at least I believe the FSM would have them) for checking for a bent chassis? What points to use for measurement ect...
I am beginning to suspect the chassis on my 96 is bent from an accident that happened a few years before I tore the car down for the full resto. Mocking up the rear the other day in order to cut/reweld the spring perches further forwards on the housing to compensate for the extended control arms I noticed that the rear end was sitting 3/8's to a half inch further to the P side. This was evident when looking at the bump stops, the pinion snubber and also running a plumb bob down through the spring pockets to the rear.
I started taking diagonal measurements from the beefy part of the frame where the LCA's mount to over to various points of reference on the rear cross member. I found most of my points to be off by about 3/8ths of an inch (longer from D side frame to P side crossmember) but a few measurements i took were as much as a half inch.
Before I go any further and waste any more time measuring, I just figured i'd find out what points the FSM recommends to measure from as I was getting 1/4" to 1/2" difference between different reference points that were within inches of eachother so I am guessing some holes just weren't drilled equally on both sides. IIRC correctly, one measurement I did from the body bushing hole in the center of the frame diagonally across to the rear body bushing near the LCA was off by like 3/4's of an inch and I don't think the frame could possibly be bent that badly.
FWIW the accident the car was in was jumping over a thick curb sideways. The D side wheel nailed the curb sideways, chewed the wheel up and bent the LCA. So now I am trying to figure out what that could have done to shift the rear over to the P side. After that accident the car had always tracked straight so I never thought anything of it. Also, when jacking up the rear, the rear end isn't any further off to the side at the all the way up position than it is unloaded...so it doesn't seem like the control arm mounting points are tweaked because the rear goes up at an arc so any difference would be greater when it was all the way up.
The rear on my 94 looks to be further in on one side too but I haven't measured to the frame, so could just be the body. Possibly it could be a factory thing that the rears didn't sit centered but then it seems odd that my frame to rear crossmember measurements would be off almost exactly how much the rear is off center (3/8ths). Unless it is all part of a factory blunder and they have some really, really poor tolerances. I normally wouldn't think this be the case but I have heard of a few B body guys say their wheels had different fitment to the frame rails from side to side.
