I have looked around the forum and the internet. I cannot find anyone with a detailed explanation or a you tube video that shows this for a 1991-1996 B-body. I need to adjust my hood stops on a 1996 Caprice that has lived its entire life in Pennsylvania.
There is nothing to grab with a wrench. I do not want to put pliers or vice grips on the rubber cushion part of the hood stops. There is some whacky 2-piece metal thing at the top of the radiator core support but I tried to unbend a couple of tabs that were bent over and the tabs just snapped off.
I have been soaking the threads with PB Blaster. Does anyone have a video or pictures that show someone adjusting these stops?
I guess that if nothing is available, I will just put some vice grips on the threads up under the cushion and try to see if anything will turn. The good news is that the stop needs to come up, so if I do ruin the upper most threads, it should not be the end of the day.
Thanks.
Thanks.
