how do i delete or disfunction the air pump
the bulletin and the guy called PADOT and asked them about it and they approved it. then hours later called back and said that guy that approved it was mistaken. if the car didnt need additional work i dont know how they would have unapproved the inspetion and ripped off my sticker from my garageI wonder if this fellow had the engine bay decal or a copy of the GM bulletin and still failed?
Nice thanks I have a 95 and have been asking if I have to reprogram the ecu now I know I dont do you know if it will cause you to fail smog?ledsled has it right. just unplug it and tie the connector outta the way. when you remove the piping they will be tack welded or rivited or something to the bracket for the alternator (ithink) just wiggle and it will pop off. what i did was take the driverside and bend the pipe back and forth until it snapped in half under the front of the engine, (cause i couldnt get it ALL out in one peice)pulled out the driver side, then worked the passenger side out. but BE CAREFULL!!! not to cut or pinch and damage the passenger plug wires that run under the alt. mines a 95 so no need to reprogram the pcm. leave the fuse in cause it runs the hood light also
its easy
Dorman has part #090-055 that is a three pack of the same M22-1.50 oil drain plug. I bought mine from Oreilly's for $4.29. This is for 94 and early 95'sThe A.I.R Pump disable process is listed here in the tech section of forum at this link:
http://www.impalassforum.com/tech/engine/air_pump/air_pump.htm
Below are pics of the AIR pump deleted, and the Oil drain plug I used to cap off the exhaust
manifolds plug for my 1995 LT1. The 94 and Early 95's are the same size, The later 95's and 96 Models
are different and use a 5/8" Flare Cap nut to plug the manifolds. These can be found at Lowes or
Home depot. Determine which manifold type you have Here (Husskers pics)
http://www.impalassforum.com/vBulletin/showthread.php?t=229732&page=2
The 96 model AIR Pump delete also requires a reprogram (OBD-II) Also, DONT use the
paper gasket that comes with the drain plug on the exhaust! Go to your local hardware store
and get a "Thin" copper or metal gasket for the setup (Pic). I Highly suggest that when your
preparing to do this removal project, lightly wire brush off the threads of the AIR Pump tubes that
go into the manifolds, Get the manifolds "Warm" (Not blistering HOT), then spray down the
threads/AIR Tube connector with PB-Blaster and let it set for an Hr, repeat the Heat/PB Blaster 1 more time.
Make sure you have the Correct size wrench for this Job!!! It is recommended that you
Use a " 6-Point Line" wrench for this Job! You may only get 1 decent shot at getting the rusted
tube fittings loose and you dont want to strip the heads in the process. Go easy and they will
come loose and out. Tighten the manifold plugs down decent but DONT over-tighten them!
6-Point Line Wrenches
AIR Pump deleted and exhaust manifolds capped
1994 and Early 95 Model AIR Pump/Exhaust manifold fitting
Description: Oil drain plug, used to cap off early model 94-95 exhaust manifolds.
Dorman Motormite 65223 Oil & Lube, Oil Drain Plugs
Dorman Motormite 65223 Oil & Lube, Oil Drain Plugs Features:
• Oil Drain Plugs
• Type: Standard
• Thread Size: M22-1.50
• Under-Head Length: 17mm
• Head Size: 19mm
• Head Style: Flanged Hex
• Brand: Dorman - AutoGrade - Oil-Tite!
Just did mine. I have a '96 and took it down to the header so I used Dorman part 65226 instead of the brass flare caps
sent from the Sith Infiltrator
Yeah it was tight. So tight I just cut it to piecesIjust finished the removal of the air pump on my wife's '95 LT1. I used the mid '80's Volvo oil pan plugs in my late '95 manifolds. I took out both the fittings because they were easy to remove. The threads are 3/4 x 16 I used pbblaster for a cuple of months before takinf it apartand they came right out. I have no CEL and the car runs great and looks better when the hood is up. The hardest part was getting the passenger side air tube out. It's tight on that side.
Chill..Just did mine. I have a '96 and took it down to the header so I used Dorman part 65226 instead of the brass flare caps.
I didn't remove the pump at the time but a couple days ago I change out the water pump and had to get the air pump out and just kept it out lol.Chill..
did you "remove" your air pump?
and if so have you passed smog test without it?
well if you use "alternate" testing....than nothing matters.
I never pass for some reason so I get it passed![]()
