After replacing the engine oil cooler lines, I'm looking to replace the rubber portion of the Trans cooler lines now. What is the pressure (PSI) that is normally seen at the cooler lines where it enters coolers?
Just want to see if the compression fittings offered by Earls and rated at 55 psi would be safe to use. I have some other options like tube sleeves/ nuts or run braided all the way from the Trans to the cooler, but this would be easiest/cost effective route I've had 3/8" brass compression fittings on there for years without issue but they look like crap now compared to the oil cooler lines. The rubber hose there now is getting soft and I want to replace anyway.
