I am considering doing this with my 1996 Impala SS. Who else uses this and what are your thoughts? Seems pretty impressive but would like to hear some reviews first and which kit you all recommend? Thanks!
Regardless of how the 0411 pcm gets utilized, upgrading any LT1 engine to use an 0411 pcm is always a good idea. How TorqHead adapts the 0411 pcm to accept LT1 connectors is exceedingly clever and very impressive.Not running the torque head, but I am running that PCM and a LS Coil on Plug Set up. I will agree with Sinister, I didn't do it because I felt the Opti wasn't up to snuff. I did it because I could. Tuning it is much faster and easier to do myself now. Standard bolt on engine upgrades or even a mild stroker build the stock PCM and Opti is still more than up to the task.
Everything I've read on the torque head kit sounds like the build quality is great and it's a very simple and straight forward install. I used the EFI Connection 24X kit, and then repinned and modified my existing harness which was not so straightforward and simple.
People who have had multiple opti failures will disagree with you; and there's nothing you can say or show them that will convince them otherwise.I will never understand why people do this. The opti works fine.
If you want coil-on-plug ignition that badly, just save your money and do an LS swap.
Did they drop the price? I remembered the Torqhead setup being well over $2000 at one point.$1200 dollars I got this done in a weekend. No way that's gonna get me an LS swap.
That part I wouldn't dispute.I can say the Torqhead is an awesome setup.
I personally have 3 Mitsubishi sensors, and I bet you could find yourself one at your local junkyard.You can't get quality GM parts anymore let alone the Mitsubishi sensor.
Did you take the time to disassemble it and prepare it correctly before installation? It doesn't seem coincidental to me that the people who are religious about this process do not complain of the opti issues that many others do.I had to go with a cardone Opti and it brand new failed less than 300 miles on my rebuilt caprice build.
Why not? An f-body is likely one of the easier LS swaps out there.On my camaro it's not cost effective to try and come up with all of the parts needed to swap it to an LS motor
You can also keep the LT1 4L60E if you feel so inclined. You will need a flexplate spacer (GM Part Number 12563532) and 6 bolts (GM Part Number 12563533). If you use the dished flexplate from a 4.8/5.3, you’ll have to put the assembly together as such: Crank, Flexplate, Spacer; if you use the flat flexplate from the 6.0L, it’ll go together like this: Crank, spacer, flexplate. If you have a Pre-1996 (1995-earlier) 4L60E transmission, you will also need to make some changes to the wiring harness inside the transmission to keep from throwing codes. If you’ve already put on a set of extended rear control arms, you should be fine with the stock driveshaft. Always check your pinion angle before you decide to deem it roadworthy.
