Rearend Widths - Chevy Impala SS Forum
LinkBack Thread Tools
Old 02-06-2010, 07:31 PM Thread Starter
Send a message via AIM to matthimself456
Rearend Widths
Im not sure is this belongs here, in wheels and tires, exterior, or suspension. Can we get a list of what rearends are what widths? I know it used to be on here but I searched some and I think its gone. I'd like to know widths for drum, Civie Disc (did those exist?), 9C1, Impala, Fleetwood, and Wagon rearends. TIA!
-Matt Brady
1996 RMW: under a perpetual knife
Other Cars: also under said knife
matthimself456 is offline
Old 02-06-2010, 08:00 PM
Navy Lifer's Avatar
Chevy
91-92 sedan
1566mm - narrow (all)
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications)
1598mm - wide (Impala SS - disc & B4U - drum)
Buick 91-96 & Fleetwood 93-96 sedans
NOTE: Fleetwood housing is unique to the application - 4-channel ABS provisions
91-96 wagon, all
1642.5mm
All 93-96 7.625" (ring gear) housings are 1598mm wide (Chevy sedan only)
Sedan housings, in both widths, have the same lower control arm bracket location/spread distance, and will fit any other sedan frame. Wagons have a wider spread distance (approx. 2") between lower control arm brackets on housing, and corresponding wider frame lower control arm mounts.
8.5" axle shaft information - sedans only
Bill Harper
ISSCA #127
[email protected]
Navy Lifer is offline
Old 02-06-2010, 08:14 PM
Send a message via AIM to Kevin Moore
Yes, in the WX3, but I think you meant the non-9C1, non-SS B-bodies, in which case, no. In fact of all the 91-96 B/D-bodies, only the 94-96 SS and 9C1 got rear discs.
Kevin
93 9C1 L05, Ex. NCSP, Silver Metallic, 312k. Dual electric fans, PVC intake w/ NAPA Gold FIL-6440 (!K&N), LT1 manifolds & cats, Pypes Race Pro SGI10R catback, SS spoiler, rear discs, Detroit/Eaton Truetrac, UMI dual Roto-joint LCAs.
95 Fleetwood Brougham, gone.
96 Roadmaster sedan, 182k, black, FE2/V92, no landau
05 CTS-V, LS6, Magnaflow, Stealth Gray/Light Gray, 120k. FG2 shocks, Creative Steel poly engine mounts, Michelin Pilot Super Sports.
05 Cadillac STS V8 AWD 1SG
99 Dodge Ram
Kevin Moore is offline
Old 02-06-2010, 08:48 PM Thread Starter
Thanks! I was mostly curious but now its here and easily search-able again.
-Matt Brady
Old 07-08-2010, 08:03 PM
Send a message via AIM to MR.ED
My 95 B4U in fact has the wider axles in it. I measured them when I switched it to discs from HD drums years ago. Turns out Im on the hunt for some myself. finally putting my gears in and found the axles just starting to wear.
95 CAPRICE,LT1,4.10 Gears,Eaton posi,T-56,Hurst B+ Shifter,Push Style Clutch,CFDF Clutch,Wilwood master,Mixed And Moded B And F Body Pedals,Howe Throwout Bearing,Mcleod Steel Flywheel,Extended polit bushing,3/8 Aluminum Bellhousing Spacer(made my own),Dennys MMC Drive Shaft,Delteq Ign System(mounted on the intake front to back),Stiff(not really)Bilsteins,T\\B Bypass,160 Stat,Meziere h2o,Rear Discs,Stealth Bolt,Braided Brake Lines,9C1 Master,Garys Cables
MR.ED is offline
Old 07-09-2010, 09:02 AM
The B4U does. You will need the longer ones. I bought Mosers for mine last year. Still have my stock ones just incase.
Troy Simmons
FASST - ROD - ISSCA
CPT Full Manual 700R4
Big Stall Big Gear
tbsimmons is offline
Old 07-18-2010, 01:12 AM
rtigues's Avatar
Send a message via AIM to rtigues Send a message via MSN to rtigues Send a message via Yahoo to rtigues
just wondering? What was the reason for the Narrow rear end in the 9C1's
1994 Bermuda Blue 9C1
Twin cone CAI, Try Y's Gen II headers, Pypes X-pipe cat-back exhaust
rtigues is offline
Old 07-18-2010, 01:41 AM
To allow for the use of snow chains.
Jim B.
fbi9c1 is offline
Old 07-18-2010, 07:24 AM
Navy Lifer's Avatar
I've made the same statement a number of times--lost to the data crash--but more to the point, prior to the 1993 body change, all 91-92 sedan housings were the narrow (1566mm) variety, which was originally dictated by the shape of the rear wheel opening.
I'm not aware of any "official" statement from within GM regarding the housing width "spec" or choice based on intended use of the vehicle, but, when the difference in width first surfaced as a Forum topic back in the first or second year of the Forum, when the learning curve was pretty steep and there was a constant barrage of questions about many of the vehicle design basics of the B-body, I said then that the only reasonable explanation was that, as an emergency service vehicle, the expectations would include the ability to fit snow chains without any concern about body clearance.
If it's anything other than that, something even more fundamental, I don't think we'll be hearing from GM about it. If it IS in writing--such as buried in the GM 9C1 specs, or in the MSP (Michigan State Police) patrol vehicle evaluation program historical files, it would be nice to find out and be able to validate the assumption.
Bill Harper
ISSCA #127
[email protected]
Old 07-18-2010, 12:13 PM
96ss_dan's Avatar
is there a way to put the fleetwood abs/ traction control system on a impala ss?
Dan Diani
1995 SS BBB T56 4.10s
96ss_dan is offline
